G0459 Grizzly 12" Baby Drum Sander Thickness sander
Started by Mad Max, June 06, 2014, 05:41:00 PM
Mad Max
I bought a G0459 Grizzly 12" Baby Drum Sander.
It has hook and loop(velcro) to hold the sand paper on.
The spong-e-ness of the hook and loop does not sand flat, I have to make about 6 passes without changing thickness to get it flatter.
has anyone took the loop off the roller and glued the sand paper to the drum?     :dunno:
I would rather fail at something above my means, than to succeed at something  beneath my means
snapper1d
That little sponginess will help you not to screw up when sanding.Those sanders have a fiber gear that will strip out if you get into a big bind and without that give you can tear up something.You are supposed to go slow when sanding and take off just a little at the time.
snapper1d
Roy from Pa
Mad Max
All right Roy, be serious and help me out   :rolleyes:
Just sanding a 3" wide piece I get(done got) a dome in the middle .
does everybody make 4 5 6 dry passes to flatten it out?
snapper1d
If it is getting domed you are trying to take off too much at a time.Remember its a sander not a planer.
snapper1d
Oh and you can crush the velcro pad if you run it in a bind also and you may have to replace that pad.Been there and done all that! Those pads are not the easiest to align up when replacing either.
Mad Max
I going 1/4 turn at a time.
How much do you turn?
Thanks   let's keep this going
bornofmud
I've been doing a half to 3/4 turn, running it through 2-3 times, then another half to 3/4 for getting the lams down to size, then go much milder as I start getting close to the target thickness.  The last 3-4 passes I don't adjust the height at all.
Roy from Pa
Mark, what grit paper are you using? I use 60 grit, many guys use 36 grit. I start a piece through and adjust so the drum starts taking off material, maybe not the entire width or length but the drum makes contact with the wood, I then keep adjusting the belt up till material is being taken off the entire piece of wood. I usually adjust the handle up one complete turn after running the board through twice. The closer I get to my finished project, I will run a board through 3 times without any further adjusting to the machine. I have never had any problems with a dome in the center.
Mad Max
Roy 60 grit
after 3 4 passes without turning the handle, it's flat
It's kind of like machine work, you can sit down while it's cutting. take it slow
Thanks
