Bamboo Backing
Started by gables, April 07, 2009, 02:33:00 PM
gables
I am working up my materials list and process for my 3rd laimnated bow. This nex bow will be the first to build with lams I have ground myself. I want to put a natural bamoo backing slat on it with minimal finishing of the nodes (kept slightly raised). I have built my previous bows back down against my form with the inflated hose. How do I deal with the radius issue with natural bamboo backing? Do I need to build a form where I laminate it belly down against the form?
"Art is thoughtful workmanship." W.R. Lethaby
Moen
If i understand you right, you dont need to make a new form. I have glued lots of boobacked bows with "firehose". But I recommend you to use tape on the laminates.
Never believe that you are worthless .... you can always be used as a bad example!
Pat B
The air hose should contour around the uneven boo back with no problem. Like Moen said tape all the compnents together first. Keep an eye on the pressed bow as it cures to be sure it doesn't slip from one side or the other.
Make the most of all that comes and the least of all that goes!
No-sage
You'll have to make another form so you can use it with the nodes up against the hose, belly down on the form.
If you want to make a one sided form, use can use clamps of innertube bands.  I use the bands cut from bicycle tubes.
dave_570
HI, this is my first post here. Do u have a
template of ur form.??? I will post some pics here
soon. showing how i make boo backed reflex-deflex.
ur method looks good.
dave_570
Muzlnbo
No-Sage,
I like the form. Is that a 2x6 and how far apart are your dowels for the bands. They look about an inch apart.
"Follow the Red Road"
dave_570
Here's another.....http://s675.photobucket.com/albums/vv120/dave_570/?action=view¤t=Picture002.jpg" target="_blank">http://i675.photobucket.com/albums/vv120/dave_570/Picture002.jpg" border="0" alt="gluing">
dave_570
sorry about that...i'm having a little trouble...
i'll get it right.....
dave_570
Ok i think i got it now....try this one....
dave_570
The result...
of the last 2 posts...
Muzlnbo
That's a nice looking bow Dave. Great work!!
No-sage
I don't have a template.
The dowels are 1 1/2" apart.  I use 2 clamps at the deepest part of the deflex to hold everything down, then after all the bands are on, I don't need the clamps anymore.
dave_570
Thanks Muzinbo, that's the accumlitive effort
of a number of years and TONS of broken staves and
experiments. That's all I make (reflex-deflex).
P.S I can't spell woth a darn , LOL!!
dave_570
BTW, the arrows in that pic are Martha Stwart
tomato stakes !!!!
dave_570
PATb.......if u wrap ur bow tight wirh stretch
wrap before u close the form. it will help
keep eveything together tight. u can see my post
further down....how i use the stretch wrap. Now I
use Box Grip 100 and ir has about a 30 min work time
before it starts to set so u have plenty of time to
do the wrapping. just a working solution....
dave_570
Sorry...that's Bow Grip 100 not Box grip.....
Pat B
Anything that will hold your lams together while you set the press up and get the hose inflated will work. I've never used stretch wrap and have only made one glass bow but having that "extra hand" really makes a difference in the end.
