Cool Pattern Started
Started by Lin Rhea, April 02, 2014, 05:09:00 PM
Lin Rhea
This will change pretty drastically but I thought this pattern looked pretty good after the first layering. I stacked 17 layers of alternating 1084 and 15N20, then I knocked the corners in and crushed it. I then cut it into 5 pieces, stacked, and welded it. It will subsequently get restacked some more but this is what it looked like at this stage.
"We dont rent pigs." Augustus McCrae
ABS Master Bladesmith
Dwyer Dauntless longbow 50 @ 28
Ben Pearson recurve 50 @ 28
Tall Tines Recurve 47@28
McCullough Griffin longbow 43@28
Bladepeek
Fascinating. Looks like you'd see on a screen in a hospital emergency room   :)
60" Bear Super K LH 40#@28
69" Matt Meacham LH 42@28
66" Swift Wing LH 35@28
54" Java Man Elk Heart LH 43@28
62"/58" RER LXR LH 44/40@28
gudspelr
That end view reminds me of a low layer version of some of your knives (I want to say laddered W's?). This will be interesting to see the side view as the pattern develops.    :campfire:
Jeremy
"Have nothing in your house that you do not know to be useful, or believe to be beautiful."
- William Morris
Craftsmen strive to make their products both.
Lin Rhea
Yes, it will be a laddered W pattern. Now there are 5 layers X 17 layers welded together. Soon it will be 45 X 17. Then the billet will be forged into one or more blades.
D.Ellis
I'll be watching this one for sure.
I have a blade bashed out with twisted w's.....or my attempt at them. So many variables with w's depending on initial stack count and then w's stack count as well as how they are crushed at first, and later manipulated.........almost endless possibilities.
I wonder if anyone has done w's rain dropped??
Darcy    :campfire:
60# GN Lil'Creep Jackknife
67# osage selfbow
62# "Zang Hill" string follow
Alexander13
Any sort of Damascus is beyond my skills right now but I really enjoy watching you guys create yours! hopefully someday I'll get to that level.
Lin Rhea
You are right Darcy. There is no end to the variety that can be achieved with this process. Even when two people who attempt to forge the same W pattern, it will be somewhat different because of the slight variations of tooling and technique.
akaboomer
I like where this is going. As always I enjoy the progress pics. Thanks for sharing.
Chris
Track
I'm sure this will be another outstanding looking pattern. Looking forward to the pics of the progression to the final blade.
Doug Campbell
Lin, I think your incapable of doing anything not "cool". You had definitely inspired me many times.    :notworthy:
Life is wonderful in Montana!!
"BEING CHALLENGED IN LIFE IS INEVITABLE. BEING DEFEATED IS OPTIONAL."
ABS Journeyman Knifesmith
Lin Rhea
I started this morning on my last weld and had to forge the "embryo" of the blade while up to heat. I snapped a shot of the rough embryo while hot. You can see the lines of the pattern in the scale. This is my normalizing cycle so the scale will be pretty heavy at this stage. I have to cut the grooves in to establish the ladder pattern and then re forge the blade thinner and finalize the profile before grinding. This blade will settle in about 12 inches X 2-1/16.
Lin Rhea
I cut grooves on regular spacing on both sides but staggered. This will give it the regularity of pattern.
As you see, the blade taper and bevels are semi forged while allowing some (not much) reduction after the grooves are ground in.
Here I am forging the grooves out and finalizing the blade's shape. As you see I am starting near the back working toward the tip.
Here is the forged blade. I have done no profiling so I may change the look some but I kind of like the profile the way it is.
It turned out to be 13 inches.
kbaknife
Aw, come on. Teaser.
I wanna see the pattern!!!!
When the last deer disappears into the morning mist,
When the last elk vanishes from the hills,
When the last buffalo falls on the plains,
I will hunt mice for I am a hunter and I must have my freedom.
Chief Joseph
Lin Rhea
OK Karl.   :)   I took a snapshot of the pattern but you'll have to ignore the scratches.
kbaknife
It's all clear to me now.     ;)
Chief Joseph
D.Ellis
That pattern looks great!
Darcy   :campfire:
67# osage selfbow
Lin Rhea
Thank you. that was about a 2 minute etch while pretty rough.
DANA HOLMAN
Lin, that's a nice pattern, but did you notice the funny face with big nose and long hair at the top of the blade? anyway can't wait to see the finish product
"When Satan is knocking at your door,
Simply say,
"Jesus, could you get that for me?"
Lin Rhea
D.Ellis
Did you get this finished yet? I have been waiting anxiously for updates on this one.......such a cool looking pattern. Don't leave me hanging Lin!   :D
Darcy   :campfire:
67# osage selfbow
